james_dean1986
Hub 3.0 not detecting ethernet cable from NVR
Had my broadband installed at the weekend. I have connected my TV box to the router via ethernet and it picks it up straight away however it will not pick up the NVR from my CCTV. I connect it back to my talktalk router and it is fine.
Any suggestions?
james_dean1986
Re: Hub 3.0 not detecting ethernet cable from NVR
Updating for anyone who faces the same issue.
Solved it my self by reconfiguring the IP address on the NVR (changed a 1 to a 0).  The router then picked it up.
