  • 5
l_ingenu
Hub 3.0 is missing Ethernet connected devices
I have the four Ethernet plugs used on my Hub 3.0.
However, I can only see 2 of them. The other two are not listed when I am looking at the Connected Devices. Any clue how I can make them appear please? I need to assign fixed IPs.
Thanks.
David.
  • 13.02K
  • 371
  • 1.06K
Moderator
Moderator
Re: Hub 3.0 is missing Ethernet connected devices
Hi David,
If you're still experiencing problems with devices not showing up as connected, then in the first instance could you please try a factory reset of the Hub and let us know if this helps.
Many thanks
Ralph_R
Forum Moderator
