luke_r
Message 1 of 8
Hub 3.0 connection dropping out
I've just had my new hub 3.0 installed and I'm immediately noticing problems - devices disconnecting, both over wireless and ethernet.
Over ethernet, I'm noticing disconnects approximately every half an hour. This isn't just a loss of internet but a complete disconnection from the hub (I can't access the admin when it happens). There are no warning lights on the hub at the time.
The network log shows no issues so I believe this to a connection problem between the hub and my devices.
I'm running on router mode and have allocated a fixed LAN IP to my ethernet devices.
  • 6.62K
  • 174
  • 438
Message 2 of 8
Re: Hub 3.0 connection dropping out
Hi there luke_r,
Really sorry to hear about the connection fault experienced.
I've located your account and I've not been able to detect any faults either via the equipment levels or network segment.
I do, however, recommend Changing your Virgin Media Hub's wireless channel, in order to improve this type of connection.
Let me know how you get on with this,
Nat_J
luke_r
Message 3 of 8
Hello,
I've been monitoring the issue since my last post - the problem is only on one device from what I can tell. It's over ethernet so the wifi solution you've suggested doesn't apply unfortunately.
I have three devices connected over ethernet; my tivo box, a raspberry pi, and my desktop. The desktop seems to be the only one dropping connection. I can see the port is inactive when it drops off (no light, compared to the others). It's not as predictable as I originally thought, it can drop out as often as 5 minutes to half an hour and sometimes several drops in a few minutes. I've tried changing port on the router and swapping the cable. I don't believe this relates to the device itself as I never had any problems with my previous routers.
Any ideas?
Luke
  • 10.66K
  • 313
  • 657
Message 4 of 8
Hey Luke,
Thanks for getting back to us Smiley Happy
Can I ask what version of Windows your desktop is running? If other hard-wired devices are performing well and you've tried additional cables and Ethernet ports, it does lead me to think this is a device specific issue. Is your desktop up to date with drivers etc?
Catch you again soon,
Take care.
Heather_J
luke_r
Message 5 of 8
I'm running Windows 10 and yes the ethernet driver is up to date.
Any other thoughts? This computer uses the internet more than any other devices in my house so it's critical that it's resolved. The constant connection loss is making it unusable.
Surely a router should be compatible with all devices, especially on the latest operating systems. My previous (BT) router never had a problem.
Luke
  • 7.58K
  • 188
  • 442
Message 6 of 8
Hi luke_r,
Thanks for getting back in touch, How does the device that is dropping out behave when it is connected via a wireless connection rather than Ethernet?
Just curious to see if it behaves better then it may be the port but if it is the same as it is with a wired connection then we will need to have another re-think.
Try the device that is dropping connection wirelessly but if possible can you also try the devices connected to a friend or neighbours connection to see if it still have the drop out issues connected to a different internet connection.
It would also help to try the device that is dropping in a a different port too.
Looking at the general connection from this side things seem to be ok from this side.
Speak to you soon.
Emma
  • 8
gordon217
Message 7 of 8
I have same issue, just Ethernet, already had Homehub 3.0 swapped out and new one has developed same fault, just Ethernet not WiFi.
  • 10.82K
  • 308
  • 632
Message 8 of 8
Hi gordon217,
Thanks for taking the time to post on the community.
Apologies you are also having an issue with the wired connection disconnecting.
Does this happen on more than one device?
Have you tried all Ethernet ports on the Hub?
Has a new Ethernet cable been tried?
Sam
