A83
Hi my broadband doesn't work properly. Low signal.
Hi my broadband doesn't work properly. No Internet 3 hours per day. Signal low upstairs and in the kitchen. The house is small.
Thanks for answer.
  • 9.48K
  • 650
  • 1.81K
Re: Hi my broadband doesn't work properly. Low signal.
could be many things - you need to do a wired test to check if all is ok with the input - if you are getting full speed then that suggests thats ok - so assumimg all is good wired you then need to look at the wifi - download something like inSSIDer for pc or similar for mobile device and check the channel that you are on - choose one that is not busy - that should help
____________________
Tony
