Arkle199
Help blue light on box and screen stuck on starting uo
Blue light on box and screen stuck on starting up
  • 3.99K
  • 202
  • 897
cybmole
Community elder
Re: Help blue light on box and screen stuck on starting uo
do you plan on telling us which box you are talking about - or are we supposed to guess ?
Arkle199
Sorry no of course i dont expect you to guess. Not the white hub the black flat box sorry my son is out or i would ask his help. Would it be easier for me to ring someone for help?
  • 3.99K
  • 202
  • 897
cybmole
Community elder
 the black box is either a Tivo if it has curved edges, or an older V box if its rectangular
 the tivo has an on-off switch at the back at the left. its always worth tying turn off. , go make a cup of te, turn on again., that fixes many bugs.
 I dunno where the switch is on the V box butt you can pull out the relevant plug at the wall instead to force off - on
 start with that, then phone in as the next step if still broke.
if you ring you get a computer voice saying "we will run some tests. leave it for 10 minutes then call back if it did not work". So it's a simple enough procedure. that hard bit is working your way through the confusing automated phone menus - you ring 150 on your virgin landline and then you want TV then faults...
