simonwhitwick
Help and advice
So, Virgin broadband was down for approx 4 hours on Monday and now broadband, TV and home phone are all not working (Eta fix time 4 hours).
Two questions: am I due a refund on my package cost (especially annoying as I was trying to work on Monday)
Secondly why when you provide a mobile number in exchange for updates on the problem resolution do you hear absolutely zip?
Your advice on how best to handle appreciated.
Simon
  • 16.49K
  • 1.37K
  • 3.36K
Re: Help and advice
hiya @simonwhitwick I believe you only get a refund for each day its off e.g. 24hrs.. since if they where to apply refund would be doing package price divide by 28 days / 24hrs * 4 hours which might work out in pennies.
