Bloat
Connection Problems - Very High Post RS Errors
I believe we have a problem with our connection. We are constantly disconnected from online gaming, videos stutter when playing back, and even web pages fail to load or take an age to resolve the address. I have checked the status of the SuperHub and found one channel, DS-3, has enormous levels of Post RS Errors.  856 Million since rebooting the Superhub last night.  The RxMER, 26.47, is much lower than all the other channels (35-37).
Do I have a problem with my Superhub or Line?
Service Status shows no problems in my area - Oldbury, West Mids
Helpful Answers
  • 2.76K
  • 223
  • 843
Dave_cq
Trouble shooter
Re: Connection Problems - Very High Post RS Errors
Right, well your power levels both Upstream and Downstream are perfectly fine.  As you say, it's that DS-3 channel that's an issue with its very low Signal To Noise Ratio of only 26.47db .  I've never seen that before where one channel is so much lower than the others but I've no doubt some forum member(s) has.  I'm sure that rogue channel will be dragging performance down.  The threshold is 34.5db and the higher the better beyond that.  None of your channels is particularly high which suggests that you do have a rather noisy connection.
Check that the cable connections to the hub and wall socket are tight and if that is not the cause I think you had better arrange an engineer's visit with VM.
********* SuperHub 2ac - Asus rt-ac68u Router - Vivid 100Mbps **********
Electron
All Replies
  • 2.76K
  • 223
  • 843
Dave_cq
Trouble shooter
Hi Bloat,
Could you post your Upstream & Downstream data  and the Network Log please.
Electron
Bloat
Hopefully this is what you are looking for..
  • 2.76K
  • 223
  • 843
Dave_cq
Trouble shooter
Electron
  • 8.32K
  • 359
  • 588
Hi Bloat,
Welcome to the Community!
Really sorry to hear you've had trouble with your connection.
I've located your account and I can see the technician has been out to fix this for you. How's it been since?
Speak soon Smiley Very Happy
Josh
Bloat
HI,
Thank you for your input and suggestions.  Engineer attended on Thursday and confirmed too low SNR on channel DS-3.  He reterminated the connection into the house and I think changed the 'tap'? point in the cabinet.  A -10db attenuator to lower the downstream power level and now I have the following after two days of uptime:
Everything seems fine now.  Consistent speedtest results and no ping loss.
Great service by the engineer.  Thank again.
