  • 6
Denty76
Message 1 of 8
Broadband problems
Hi, I seem to be having problems with my broadband where it seems to be glitching. Once a week there seems to be a problem where it's as if it's dropping out all the time. I've been on my virgin and ran a test on each of these occasions it says there's a problem,although it doesn't say what the problem is. Anyways 10 minutes later restart and everything's great. One week later back to the same old problem. Before I phone virgin, I just wondered if anybody else has had this same problem? Thanks
  • 16.49K
  • 1.37K
  • 3.36K
Message 2 of 8
Re: Broadband problems
hiya @Denty76 would need to run some check on the hub if you could goto http://192.168.0.1 clicking router status top right [no need to login] and if could copy/paste the downstream, upstream, network log this might show possible cause.
  • 6
Denty76
Message 3 of 8
DS-3 DS-4 DS-5 DS-6 DS-7 DS-8
Frequency (Hz) 219000000 Hz 227000000 Hz 235000000 Hz 243000000 Hz 251000000 Hz 259000000 Hz 267000000 Hz 275000000 Hz
Lock Status(QAM Lock/FEC Sync/MPEG Lock) Locked Locked Locked Locked Locked Locked Locked Locked
Channel ID 7 8 9 10 11 12 13 14
Modulation QAM256 QAM256 QAM256 QAM256 QAM256 QAM256 QAM256 QAM256
Symbol Rate (Msym/sec) 6.952000 6.952000 6.952000 6.952000 6.952000 6.952000 6.952000 6.952000
Interleave Depth I=12
J=17 I=12
J=17 I=12
J=17 I=12
J=17 I=12
J=17 I=12
J=17 I=12
J=17 I=12
J=17
Power Level (dBmV) -0.4 dBmV -0.3 dBmV -2.0 dBmV -2.3 dB
Upstream
US-1 US-2 US-3 US-4
Channel Type 2.0 2.0 2.0 2.0
Channel ID 50 49 51 52
Frequency (Hz) 39400000 Hz 46200000 Hz 32600000 Hz 25800000 Hz
Ranging Status Success Success Success Success
Modulation QAM16 QAM16 QAM16 QAM16
Symbol Rate (Sym/sec) 5120000 5120000 5120000 5120000
Mini-Slot Size 128 128 128 128
Power Level (dBmV) 47.8 dBmV 48.0 dBmV 46.3 dBmV 45.3 dBmV
T1 Timeouts 0 0 0 0
T2 Timeouts 0 0 0 0
T3 Timeouts 0 0 0 0
T4 Timeouts 0mV -1.1 dBmV -0.9 dBmV -0.9 dBmV -1.2 dBmV
RxMER (dB) 39.0 dB 39.4 dB 39.2 dB 39.4 dB 39.5 dB
  • 16.49K
  • 1.37K
  • 3.36K
Message 4 of 8
those are all showing perfectly fine, this would require a network check by the forum admin which can take around 5+ days to get reply, you could call back to broadband support via 151 / 0345 454 1111 online chat http://contact.virignmedia.com
could you also post the network log, or is that empty?
  • 10.66K
  • 313
  • 657
Message 5 of 8
Hi Denty76,
Thanks for getting in touch, I hope you're well Smiley Very Happy
Sorry to hear about your broadband troubles, this can be frustrating.
I agree with paultechy that nothing obvious is standing out in error. I can see you're currently only using wireless devices, do you have the same troubles on your hard-wired connections?
Please get back to us so we can continue to investigate.
Take care.
Heather_J
  • 6
Denty76
Message 6 of 8
Description
19/01/2017 01:11:50 19/01/2017 01:11:50 Error (4) 68010400 DHCP REBIND WARNING - Field invalid in response ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/01/2017 02:49:12 20/01/2017 02:49:12 Critical (3) 2436694078 TOD established
  • 6
Denty76
Message 7 of 8
yes that's where I first notice it to be fair, online gaming is sluggish and glitchy 😔. That's for your help
  • 3.88K
  • 121
  • 203
Forum Team (Retired) Adam_L
Message 8 of 8
Hi Denty76,
Thanks for the post! I am sorry to learn about your issues with your broadband glitching, I apologise for any inconvenience caused.
I have run some tests from here and I can see that there's been quite a few T3 time outs occurring since you last rebooted your Hub, I would like to arrange for an engineer to attend and resolve this for you.
I will send you a PM (purple envelope at the top) detailing what's required in order to proceed with making the booking, please respond to me there and I'll get this all sorted for you.
Take care,
Adam.
