  • 29
yadesai
Are my power levels within range?
Hi. I have been having a issues with my broadband and was hoping to get my power levels and SNR on the down and up stream checked by someone more knowledgeable then me to see if that is where my issues are. I believe there are within range but just wanted to get them double checked. I have a hub 3.0
Channel
Frequency(Hz)
Power
(dBmV)
SNR
(dB)
Modulation
Channel ID
1
299000000
5.6
40.3
256 qam
17
2
323000000
5
40.3
256 qam
20
3
315000000
5.1
40.9
256 qam
19
4
307000000
5.3
40.3
256 qam
18
5
291000000
5.5
40.3
256 qam
16
6
283000000
5.5
40.9
256 qam
15
7
275000000
5.6
40.3
256 qam
14
8
267000000
5.8
40.3
256 qam
13
9
259000000
5.9
40.3
256 qam
12
10
251000000
6
40.3
256 qam
11
11
243000000
6
40.3
256 qam
10
12
235000000
6.3
40.9
256 qam
9
13
227000000
6.4
40.3
256 qam
8
14
219000000
6.5
40.3
256 qam
7
15
211000000
6.5
40.9
256 qam
6
16
203000000
6.9
40.3
256 qam
5
17
195000000
7.1
40.9
256 qam
4
18
187000000
7.4
40.3
256 qam
3
19
179000000
7.3
40.3
256 qam
2
20
171000000
7.6
40.9
256 qam
1
Channel ID
Frequency(Hz)
Mode
Power(dBmV)
Modulation
Channel Bandwidth(Hz)
Symbol Rate (ksps)
39
32600000
ATDMA
42
64 qam
6400000
5120
37
46200000
ATDMA
42
64 qam
6400000
5120
Cable Modem Status
Item
Status
Comments
Acquired Downstream Channel(Hz)
299000000
Locked
Ranged Upstream Channel(Hz)
39400000
Locked
Provisioning State
Online
Helpful Answers
  • 1.72K
  • 155
  • 465
Re: Are my power levels within range?
All good. What are the issues?
Dave.
All Replies
  • 1.72K
  • 155
  • 465
Dave.
  • 29
yadesai
every few days it needs a restart as the ping becomes quite high but once its restarted its fine for a couple days. It was worse but an engineer came few weeks ago and replaced all the isolators and connectors as well as the hub.
What are the typical issues when power levels and SNR are out of the acceptable range?
  • 20.93K
  • 564
  • 3.3K
Sephiroth
The issues are described in the POWER LEVELS & SNR sticky thread at the top of the page.
