Ask a question
Fresh as a Daisy
da021v1927
please help!!!! 192.168.0.1 doesn't work
I have other people living in my house and using my internet i need to change the password on the hub but the web address doesnt work. im gettting frusrated and dont know what to do.
please help thanks
Please use plain text.
adacom
Re: please help!!!! 192.168.0.1 doesn't work
which hub is it - if a super hub then it should work - you could try 192.168.100.1 - thats modem mode but also works in normal mode
if its not the hub or super hub then post back with details
____________________
Tony
Gandalf
Do a reset of the hub to change to password back to default.
http://help.virginmedia.com/system/selfservice.controller?CONFIGURATION=1002&PARTITION_ID=1&TIMEZONE...
Now try 192.168.0.1.
------------------Die-hard direct connection modem user :smileytongue:
Believing is catch 22 the VMDG280 should never of been made the Super hubs 1 & 2 could have been built better the years go by and we can't see the mistakes that were made to make things right.
The more that use modem mode the more we need IPv6: BQM, Outgoing ports test
Freakishly Helpful
jhuk
http://192.168.100.1/  Is and always has been the address for all my modems inc SuperHub.
Good to Know
Oliver_C
Hi da021v1927,
Are you still experiencing problems accessing the router configuration pages? Did any of the help posted on your forum resolve your issue?
Kind Regards,
Oliver C
Help & Support Forum Team
If someone's helped you out say thanks by clicking on the Kudos Star. If someone's solved your problem, why not mark their message as a Helpful Answer? You can also help other users find useful posts by Tagging them with keywords.
If you are new to the forum, please remember to search the forum before posting your question. Please don't send private messages directly to the forum team unless they ask you to, post your issue to the forum first.
Making Waves
homeworker
I have this problem as well.
I dont want to reset as I'll lose the previous settings and I cant remember what they were.
Wirelessness is working fine. I just cant login to the superhub either wirelessly or by direct cable connection.
using either 192.168 address.
Actually, I just want to enable the port 6881 for easybit torrent. Am I barking up the wrong tree anyway?
Making Waves
OnlyForIssues
[ Edited ]
Aah, I was wondering what was going on, all of a sudden I couldnt connect through 192.168.0.1. was there a hub update?(do they update?) if so how come it changed to 192.168.100.1? or is there another cause of this?
Mythical
jb66
100.1 has always worked as that's the modem ip address
No longer registered
Making Waves
OnlyForIssues
so previous to what ever happened the other day, I would have been able to connect through both 0.1 and 100.1? is there a reason why I  can now only connect through 100.1? it's not an issue, im just interested in what happened.
Mythical
jb66
Are you in modem mode?
