Ask a question
Bright Spark
F Secure problem
I have just installed F secure as Virgin security is no longer available. After installation my PC slowed down, then Windows would not open, after a windows  repair all seemed Ok till a turned on my PC the next day, since then it runs really slow and takes about 10 minutes to get onto the Internet and open up other programmes.
My operating system is windows 7. Has anyone else had problems?
Re: F Secure problem
Hi geoffs,
Sorry to hear that F-Secure security is causing problems, sounds like a possible memory problem, how much RAM do you have installed and how are system resources looking?
It may also be worth checking out the F-Secure Forum for additional information on this kind of issue.
Kind Regards
Ralph
Help & Support Forum Team
Problem Solved?Fault with your service?We did warn you!
