tustin
wireless
since i was installed in october im unable to connect to wireless says its not enabled and im unsure how to enable it can any1 help please thanks in advance.
  • 16.52K
  • 1.38K
  • 3.38K
Re: wireless
What device are you trying to connect wirelessly? Also what light's are on the hub
tustin
Re: wireless
i only have 1 light on on my hub.
  • 16.52K
  • 1.38K
  • 3.38K
Re: wireless
i take it your using a hub3, but didn't say what device you trying to connect to the wireless.. you could check the wireless is on by logging into the hub via http://192.168.0.1 logging details are on the sticker, and goto wireless settings.. this will show your wireless name, wireless passphrase aka password.
