  • 9
joshy
wired connection
I had full package installed a week ago, wired connection to downstairs desktop and wired connection to upstairs desktop, 3 days ago I lost the wired connection to upstairs and it is now on wireless, when I go to set up  an Ethernet connection on upstairs desktop it just says no Ethernet cable connected, I have replaced the cable with a new one but still no joy, I have also reset the s/hub 3 without any joy, can any one help  with this issue.
Helpful Answers
  • 22.28K
  • 855
  • 3.24K
Re: wired connection
try another port on the SH. you said you have 2 wired PC try the cable of the upstairs in the port the downstairs one is using on the SH. if that fails its the cable (maybe you have another bad) or the pc network card maybe
  • 9
joshy
apcyberax
Thanks for your reply, I tried what you said and I got a wired reading of 219mb on my other desktop from downstairs on the upstairs Ethernet, I switched everything back and now the upstairs desktop is getting the same reading, Very strange, But I'm happy it has gone back to wired at 219mb.
All Replies
  • 22.28K
  • 855
  • 3.24K
  • 9
joshy
apcyberax
