jericho5617
wifi
hi all dont know if this is a problem but the past 2 days i have got my wifi light flashing all the time never happened before should it be doing this thanks
  • 3.88K
  • 121
  • 203
Forum Team (Retired) Adam_L
Re: wifi
Hi jericho5617,
Thanks for the post! I am sorry to hear about your issues with your WiFi light flashing all the time, I apologise for any inconvenience caused.
I have run some tests and I can see that you have a Hub 3.0 and this shouldn't be happening on that particular model. Are you still having the same troubles with the WiFi light flashing?
If so, are you experiencing any issues with the connection itself, e.g dropping, slow etc?
Also, you can try a factory reset of the Hub to see if that helps.
I look forward to hearing from you,
Adam.
