  • 7
bruce9903
wi fi and wired connections dropping off
Help !!!
I am experiencing regular problems with both wi fi and wired connections dropping off , have tried all the suggested hard resets , it effects what ever devices are in use at the time .
Any suggestions ???
Cheers Bruce
  • 9.47K
  • 649
  • 1.81K
Re: wi fi and wired connections dropping off
log into superhub - 192.168.0.1 - DON'T SIGN IN, click router status  - and post the downstream and upstream figures
____________________
Tony
  • 7
bruce9903
Hi Tony
I have tried a few times to connect to 192.168.0.1, will not connect , keeps timing out .
Bruce
  • 9.47K
  • 649
  • 1.81K
not good - what are the lights doing on the front of the hub - check the status page although that only shows bigger problems - a call to 150 if you have a VM phone line can get a status message sometimes - failing that you need to ring and hope offshore can help - they will take you through their scripts which usually start with a power cycle and unless its obvious to them usually leads nowhere - they should book a tech though if its not an area fault
you can wait here for VM to look but that takes a week or so
Tony
  • 7
bruce9903
Hi , thanks will contact VM tomorrow when I have time to sit through the help options
Bruce
  • 3.88K
  • 120
  • 203
Forum Team (Retired) Adam_L
Hi bruce9903,
Thanks for posting! I am sorry to hear that your WiFi and internet connection has been dropping on and off, I apologise for any troubles incurred.
I have tested things from here and I can see a few T4 time outs inside the Hubs logs and I would like to arrange for an engineer to attend and investigate this further for you.
I will send you a PM (purple envelope at the top) detailing what's required to proceed with making the booking. Please respond to me there and I'll get this sorted for you.
Take care,
Adam.
