swetchias
Message 1 of 7
virgin media hub 3.0,no port forwarding in advanced settings!
  • 1.43K
  • 154
  • 458
Message 2 of 7
Re: virgin media hub 3.0,no port forwarding in advanced settings!
swetchias
Message 3 of 7
as you can see under security i have only:firewall,MAC filtering and IP and PORT filtering nothing else
  • 1.43K
  • 154
  • 458
Message 4 of 7
Currently seeing this (below) for your post due to whatever image clearing process Virgin Media deploy on forum.
swetchias
Message 5 of 7
  • 1.43K
  • 154
  • 458
Message 6 of 7
If you have not already tried, see if this YouTube video is of help: Virgin Media HUB 3.0 | Complete Guide to PORT FORWARDING for PS4 + XBOX One + PLEX
BTW, screen captured images have finally cleared and with their appearance there will hopefully be posts from those more experienced with the Hub 3.0
  • 1.43K
  • 154
  • 458
Message 7 of 7
You shouldn't need to enable remote access for port forwarding to work. That said, there are some glitches with port forwarding which relate to firmware issues that we're working on.
Source: Re: Do I need to enable remote access to make port forwarding work on hib3
