joemurdoch
Message 1 of 7
using asus dsl-N55U as router and superhub as modem
Hi, i currently have it this setup with the superhub in modem mode and an ethernet cable running from the hub to the asus router and is connected into port 1.
i have set the asus router to dual wan mode and wan type as LAN , it is running and have internet connection although its only 2,3 dl speed and is flakey.
is it because its a WAN ? am i doing this right ?
  • 16.12K
  • 1.34K
  • 3.27K
Message 2 of 7
Re: using asus dsl-N55U as router and superhub as modem
hiya @joemurdoch since that router was designed for ADSL aka broadband via the telephone line, should be getting much higher speeds, but should be getting good speeds using a Ethernet port.
best idea would be to do a direct connection from hub to PC/laptop, reboot the hub and see if you speed increases... also adviseable to run a check on the signal levels if you could goto http://192.168.100.1 clicking router status top right [no need to login] and if could copy/paste the downstream, upstream, network log (don't worry about formatting we can easily read it)
joemurdoch
Message 3 of 7
i have a cable that is ethernet to phoneline (Rj45 to Rj11) could i use this from HUB port 1 in modem mode into the phoneline input on the asus router ?
  • 16.12K
  • 1.34K
  • 3.27K
Message 4 of 7
using (Rj45 to Rj11) might cause even slower connection but cant hurt to test it.. if the WAN connection support dhcp on WAN port. rather than pppoe etc.
joemurdoch
Message 5 of 7
just says no phone line connected and theres no internet with Rj45 to 11 cable , so back using ethernet any ideas ?pic 4.PNG
joemurdoch
Message 6 of 7
it goes from like 70dl to 1dl :/
  • 16.12K
  • 1.34K
  • 3.27K
Message 7 of 7
from 70dl to 1dl?? you talking the broadband speed from 70mbps to 1mpbs?, is this doing a direct wired connection?
