chrisyaxley69
super hib 2ac problems
hi i have had problems.with my super hub 2ac since beggining first had range problems which still exist but got used to it now but now it wont let me connect to the wifi networks it goes to connect then just stops without a error message anyone else had thia problem can temp fix be restarting router but only a temp fix had tried restoring it to original settinga but still does it think its a hardware problem
  • 3.88K
  • 121
  • 203
Forum Team (Retired) Adam_L
Re: super hib 2ac problems
Hi chrisaxley69,
Thanks for letting me know about your issues with your connection, I apologise for any inconvenience.
I've tried testing things from here but I was unable to locate any of your details via your forum account. In order to proceed with diagnostics I will need to confirm a few details with you.
I will send you a PM (purple envelope at the top) detailing what's needed in order to proceed. Please respond to me there and I'll get this all sorted for you.
Take care,
Adam.
