richard32
Just joined
slow speed
at times we suffer from very slow board band speed and loss of compete signal
  • 2.96K
  • 378
  • 939
Re: slow speed
Are you using a wired Ethernet connection to the VM hub or a wireless connection? Wireless is easily disrupted by a number of external factors, so a wired test is the best way to get a true picture of what speed your line is able to achieve. It also helps to pinpoint if the issue is with the wireless or your line.
Are you seeing slow speeds all day or only at peak times (typically 4pm-11pm weekdays and weekends)? Some areas are suffering with over utilisation, which results in very slow speeds at peak times but full speed at off peak times.
______________________
Scott
  • 10.82K
  • 308
  • 631
Re: slow speed
Hiya richard32,
I'm sorry that you are having issues with your broadband connection.
I've managed to locate your account and the network segment is running stable with no errors.
With the broadband speeds, can you complete a speed test through a wired connection and let us know what you achieve please?
In regards to the signal, is this in relation to the wireless connection? If so you can change the wireless channel to improve this.
Let us know how you get on
Sam
