  • 11
dsr1993
Message 1 of 5
port forwarding and ip address
My router re set it's self and everything work fine apart from my DVR for my cctv.  I am unable to login to the hub with the ip address from the back of the superhub.  looked on my computer and found another ip address but still unable to login to the hub.  how can I fix this, when I go on line and ask what is my ip address I get a completely different number.  I have been told by the people whi installed the CCTV that if I port forward this will fix it.  but they are going to charge me a £50.00 call out to fix it.
  • 8.62K
  • 552
  • 2.38K
Message 2 of 5
Re: port forwarding and ip address
Your IP for your hub is 192.168.0.1
  • 11
dsr1993
Message 3 of 5
thanks, that was the one on the back of the modem, but when I put this into my search bar nothing happens, it say the page can't load
  • 8.62K
  • 552
  • 2.38K
Message 4 of 5
If you are putting it in the address bar, not the search bar, then you need to reset your HUB.
If it doesn't work after a hard reset (power cycle) , try a pinhole reset (restore factory defaults)
  • 8
79vwcrewcab
Message 5 of 5
Try ipconfig/all from command line this will give you your default gateway which will be the vm hub address.
