  • 9
daveinwirral
my samsung s7 edge gets 125mb speed but my laptop only gets if luck 55mb
I have had the 200mb upgrade, I am aware there have been issues in my area which im told are resolved, however I cannot work out how my lap top is so much slower yet my samsung 7 edge can do 125mb  (  though the engineer on his phone over a year ago had 200mb )
what can i do?
  • 8.8K
  • 600
  • 1.74K
Re: my samsung s7 edge gets 125mb speed but my laptop only gets if luck 55mb
depends on the port on the laptop, many laptop ports top out at 100mb and generally the best you'll get is 80, same for wireless, check out you laptops specs
