  • 6
vwm
lost wifi connection
my laptop wifi was fine this morning and now I cannot connect. How do I resolve this. I am not a 'techie'
  • 16.09K
  • 1.34K
  • 3.26K
Re: lost wifi connection
what happens when you try a connect? any error message, what version of operating system are you using e.g. xp,vista,7,8,10 etc.. does your laptop pick up any other wifi connections, what lights are showing on the hub?, when posting questions/issues can you supply as much detail as possible might even if you don't think its relevant.. just don't post any personal account numbers etc..
  • 6
vwm
Thank you. My problem now solved by going into cmd and resetting connection. will follow your advice if I need future help.
