walshy5050
Message 1 of 5
keep having to reset hub 2
Hi there having problems with internet i keep having to reboot my super hub 2 3 to 4 times a day i have attached the router GUI below
http://www.thinkbroadband.com/ping/share/40c6f32ec59ce4800defd2cf82bf3d5b.html
and a link to a live monitor
hope you can help
  • 16.1K
  • 1.34K
  • 3.27K
Message 2 of 5
Re: keep having to reset hub 2
hiya @walshy5050 welcome to the virginmedia community forum, the Post RS errors are rather high on DS-6,7,8 etc.. if you reset the counter do they still go up?, also with the connection does the lights on the hub go out?, as in rebooting itself..
  • 9.01K
  • 759
  • 1.88K
Message 3 of 5
The stats look fine.
Are yoy experiencing the dropouts on a wired or wireless connection?
If wireless try wired directly to the hub by ethernet cable.
Your TB graph is showing al red, either the hub is offline, or you haven't enabled Respond to ICMP Echo Requests in the hub's GUI
walshy5050
Message 4 of 5
thanks for the reply i have reset the counter over the weekend as for the lights they all stay on is s though every thing is just slowing down and as soon as i reboot all is ok for a day or 2.
well my new vm superhub 3 has arrived today so i will see how this goes.
as a general question how many devices can the vm superhhub 3 manages
thanks again guys
  • 7.26K
  • 306
  • 520
Message 5 of 5
Hi walshy5050,
Thanks for posting!
How's your new Hub 3.0 going?
In answer to your question, the Hub 3.0 has the IP range for 254 devices, but each device will have equal share of the speed.
Hope that helps Smiley Very Happy
Josh
