  • 191
Wildie
hub 30
what a load of tos it is slow interface and lots of steerlist rubbish seeing same mac codes 2 3 times in the lis,t and there  is the issue our ipcam no longer works with the hub, i can see it i cannot ping it cannot veiw it cannot log onto it have to use wired to use it not what they was bought for cannot see us running cat5e outside.
so why have we been sent a broken hub
  • 191
Wildie
Re: hub 30
we need our wifi ipcams to work come on vm why is the hub not letting us ping anything on lan .?
  • 1.28K
  • 96
  • 236
stevedh2
Knows their stuff
Re: hub 30
When you connect them wired can you ping them then?
  • 191
Wildie
Re: hub 30
yes ping on wired no ping on wifi at all the cams have 2 macs one for wired and wifi same ip show up on hub but wifi will not ping and we cannot connect to them, the lan side we messed with the settings firewall wise so pings wired i mess some more then its splashing out for a real router not some made up bolt on with bad firmware.
  • 191
Wildie
Re: hub 30
C:\WINDOWS\system32>ping 192.168.0.27
work that out makes no sense to me none, seams it`s not routing there is nothing on 13 nadda where that come from?
Pinging 192.168.0.27 with 32 bytes of data:
Request timed out.
Request timed out.
Reply from 192.168.0.13: Destination host unreachable.
Reply from 192.168.0.1: Destination host unreachable.
  • 191
Wildie
Re: hub 30
ok messed some more and turned off the hubs fire and everything security wise and now the cams can be seen and pinged oh dear open for abuse not good....
