mohikan22
hub 3 mac address issues
hi, after ringing virgin media they have no answer but believe it a firmware issue..... I can add people to the mac address list with no problems and it will deny internet access ok. However if I try and add a time schedule whether it be for one mac address or multiple, it just crashes the box and you have to reboot it. I have tried several times to add a schedule but its not having it. any ideas?
Helpful Answers
  • 16.52K
  • 1.38K
  • 3.38K
Re: hub 3 mac address issues
hiya @mohikan22 if you could take a look at guide -> http://community.virginmedia.com/t5/Switched-On-Families/Set-internet-time-limit-for-child/td-p/3138... wrote by Shelke see if this works, possible best doing a pin hole reset on the hub first..
All Replies
  • 16.52K
  • 1.38K
  • 3.38K
mohikan22
thanks. after much reading its gonna be less hassle to continue manually selecting mac addresses Smiley Happy
