jonjumpz
Just joined
how much gb of wifi Iḿ using each month??
Basically I´ve tried calling and every option just goes to automated messages, all i want to do is speak to someone to find out if they can tell me how many gb of wifi I use up/go through averagely each month.
  • 10.82K
  • 309
  • 632
Re: how much gb of wifi Iḿ using each month??
Hi jonjumpz,
I appreciate your query in regards to how much data you have used and apologies for any inconvenience caused.
In regards to this issue, I have sent you a Private Message (right corner, right corner) to discuss this further.
Hope to hear from you soon
Sam
  • 22.39K
  • 863
  • 3.26K
they can not tell you how much wifi you use. that would be local to your network.
