connor2121uk
getting fibre to my building
I have a virgin media fibre feed unterminated going to my building.
My question is can I use it to get fibre broadband currently there is no fibre in my area.
  • 16.1K
  • 1.34K
  • 3.26K
Re: getting fibre to my building
hiya @connor2121uk welcome to the virginmedia communtiy forum, would it be possible you could take a picture of this 'fibre feed unterminated' since if you trace this cable where does it go to? also you can register your interest via -> http://www.virginmedia.com/cablemystreet/
connor2121uk
cable inside the buildingcable inside the buildingcable coming outside of the buildingcable coming outside of the buildingcable going down into ntl boxcable going down into ntl boxntl boxntl boxntl box right next to adsl telephone boxntl box right next to adsl telephone box
connor2121uk
thanks for your quick reply @paultechy .
here are the photos.
