jerict1
ethernet issues
My hub now says that I have nothing connected to the router via ethernet which I have - wireless seems fine - error message when I try and resolve the networking issue says 'ethernet does not have a valid IP configuration'
  • 13.14K
  • 375
  • 1.07K
Moderator
Moderator
Re: ethernet issues
Hi jerict1,
Bit of strange one, do any of the ethernet ports work? Is the new development or always been an issue as far as you're aware? Have you tried a different ethernet cable?
In the first instance I would suggest a quick factory reset if problems remain ongoing, let us know if this helps.
Cheers
Ralph_R
Forum Moderator
jerict1
Re: ethernet issues
Factory reset - seemed to do the trick - thanks
