stevej-hos
connecting a p2p camera to a superhub
Hi, I've bought two CCTV P2P cameras that work well over the network with cable connection, but do not work with wireless. It appears I need Port Forwarding, but cannot fathom the settings as the cameras do not have IP addresses.
Any ideas???
  • 8.62K
  • 552
  • 2.38K
Re: connecting a p2p camera to a superhub
Allocate them static IP's. Then do the port forwarding.
stevej-hos
Yep thought of that but the superhub does not posses this facility.
As I can't 'see' the cameras Mac address I am unable set a static IP in any case.
I can view over an ethernet connection via the hub or direct to a laptop, but not via a P2P connection.
I understand Port Forwarding but just do not know how to access the MAC or IP address on the camera. It only has its P2P code on the label.
  • 8.62K
  • 552
  • 2.38K
Which HUB are you using?
