alimcs
can't connect Samsung j3 to wifi
Hi I have a new phone Samsung j3.  It won't connect to my hub 3.0, my husband is connected to the wifi.  It is not visible on my wifi list on my phone but there are other neighbouring properties who have virgin on the list.
Helpful Answers
  • 16.52K
  • 1.38K
  • 3.38K
Re: can't connect Samsung j3 to wifi
its possible you might need to split the wifi networks, to do this need to login into hub via http://192.168.0.1 log in details are on the sticker on the hub, and go into wireless settings and where it has the 2.4 ghz and 5ghz give them different names and apply/save
All Replies
  • 16.52K
  • 1.38K
  • 3.38K
alimcs
I am now connected to my wifi !! Thanks for your help Smiley Happy
