  • 5
andybradley20
Message 1 of 10
Work vpn doesn't work with sh3
VPN is not working with super hub 3. The old v2 had IPSec pass through. Are you aware of this?
Helpful Answers
  • 5
andybradley20
Message 3 of 10
Re: Work vpn doesn't work with sh3
Yes it does but that would mean buying a new router. Is this something you could supply due to this problem?
All Replies
  • 10.82K
  • 309
  • 632
Message 2 of 10
Hi there andybradley20,
Thanks for taking the time to post back on the community.
I'm sorry to read that you are having an issue with a VPN through the Hub 3.0.
With the Hub 3 there is not an option for IPSec pass through, I'm afraid.
Does the VPN work if the Hub 3 is in modem mode?
Hope to hear from you soon
Sam
  • 5
andybradley20
Message 3 of 10
  • 5
andybradley20
Message 4 of 10
Where is your response?
  • 9.81K
  • 686
  • 1.92K
Message 5 of 10
response will be - no - sorry
you could push them to re activate the SH2 if you still have it - depends on what package you are one but some have got them to allow then to go back to SH2 even on speeds that are said not to be supported
____________________
Tony
  • 11.04K
  • 326
  • 672
Message 6 of 10
Hello andybradley20,
Thanks for getting back to us Smiley Happy
Tony is correct, we're not able to supply you with a 3rd party router I'm sorry. Have you explored all the options, port forwarding, DMZ etc?
Sincere apologies for any inconvenience caused.
Take care.
Heather_J
  • 5
andybradley20
Message 7 of 10
I've phoned up technical support to enable my old super hub 2 and it works now but my up speed is very slow 6mb
  • 12.67K
  • 360
  • 1.47K
Message 8 of 10
Hi andybradley20,
I've run some diagnostics from here to see if I can spot any reason for that speed but I'm not currently able to retrieve the Hub power level data. Would you mind browsing to your Super Hub's Interface pages and posting the data for me?
  • Navigate to 192.168.0.1 in your browser
  • Don't login, click on Router Status, top left
  • On Upstream select the Power Level (dBmV) data
  • On Downstream select the Power Level (dBmV)
Paste the data on here please.
I'd also like to know if your speeds are from devices connected via wireless or Ethernet.
Jen
  • 10
Liamurphy1920
Message 9 of 10
yeah Hub 3.0 does not work with VPN's full stop ask for your 2.0 ac back works fine no issues
  • 10
Liamurphy1920
Message 10 of 10
Heather, you keep giving people this advice the problem is Hub 3.0 does not work with VPN's its a software issue i don't know why your recommending all this stuff the 2.0ac works fine i know because i spent weeks with the 3.0 doing all this stuff pulling my hair out till i discovered change to old router bingo works no messing about with DMZ or anything else until you fix the software on Hub 3.0 PLEASE advice correctly on it being firmware issue.
