  • 51
  • 17
chrissieb71
Dialled in
Wireless network
is there a way of checking what devices are connected to my home network?
Helpful Answers
  • 16.11K
  • 1.34K
  • 3.27K
Re: Wireless network
hiya @chrissieb71 yes you can if you take a look at -> https://help.virginmedia.com/system/selfservice.controller?CMD=VIEW_ARTICLE&ARTICLE_ID=27572&CURRENT... shows all devices connected either wired/wireless into hub.
All Replies
  • 16.11K
  • 1.34K
  • 3.27K
