hamzer
Wireless keeps dropping - Multiple T3 errors
My wireless connection keeps dropping for a couple of seconds every 10 minutes or so which makes playing games online and streaming videos practically impossible. I went on the VM status site and when running a test on the broadband, i got the below message. I've been getting this for about a week now.
I've looked at the router status and below is the outcome.
First Time Last Time Priority Error Number Description
15/01/2017 11:25:45 GMT 15/01/2017 11:25:45 GMT Critical (3) 82000200 No Ranging Response received - T3 time-out
13/01/2017 19:50:40 GMT 13/01/2017 19:50:40 GMT Error (4) 68000411 TOD error 4740 msec
12/01/2017 19:30:15 GMT 12/01/2017 19:30:15 GMT Error (4) 68010302 DHCP WAN IP - 82.10.*****
12/01/2017 19:29:17 GMT 12/01/2017 19:29:17 GMT Error (4) 68000407 TOD established
Time Not Established Time Not Established Notice (6) 84000510 Downstream Locked Successfully
12/01/2017 19:24:14 GMT 12/01/2017 19:24:14 GMT Warning (5) 66050310 Auth Success - Web login successful.
11/01/2017 11:08:42 GMT 11/01/2017 11:08:42 GMT Critical (3) 82000200 No Ranging Response received - T3 time-out
10/01/2017 22:51:37 GMT 10/01/2017 22:51:37 GMT Critical (3) 82000200 No Ranging Response received - T3 time-out
10/01/2017 21:51:46 GMT 10/01/2017 21:51:46 GMT Error (4) 68010302 DHCP WAN IP - 82.10.******
10/01/2017 21:50:48 GMT 10/01/2017 21:50:48 GMT Error (4) 68000407 TOD established
10/01/2017 21:16:49 GMT 10/01/2017 21:16:49 GMT Error (4) 68010302 DHCP WAN IP - 82.10.******
10/01/2017 21:15:52 GMT 10/01/2017 21:15:52 GMT Error (4) 68000407 TOD established
Time Not Established Time Not Established Critical (3) 82000200 No Ranging Response received - T3 time-out
10/01/2017 21:13:57 GMT 10/01/2017 21:13:57 GMT Warning (5) 66050310 Auth Success - Web login successful.
10/01/2017 21:13:39 GMT 10/01/2017 21:13:39 GMT Warning (5) 66050310 Auth Success - Web login successful.
10/01/2017 20:40:27 GMT 10/01/2017 20:40:27 GMT Warning (5) 66050310 Auth Success - Web login successful.
Downstream   DS-1 DS-2 DS-3 DS-4 DS-5 DS-6 DS-7 DS-8
Frequency (Hz) 266750000 274750000 282750000 290750000 298750000 306750000 314750000 322750000
Lock Status(QAM Lock/FEC Sync/MPEG Lock) Locked Locked Locked Locked Locked Locked Locked Locked
Channel ID 13 14 15 16 17 18 19 20
Modulation 256QAM 256QAM 256QAM 256QAM 256QAM 256QAM 256QAM 256QAM
Symbol Rate (Msym/sec) 6.952000 6.952000 6.952000 6.952000 6.952000 6.952000 6.952000 6.952000
Interleave Depth I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
Power Level (dBmV) -2.30 -2.20 -2.29 -2.39 -2.41 -2.56 -2.59 -2.62
RxMER (dB) 37.64 37.94 37.94 37.94 38.26 38.26 38.26 38.26
Pre RS Errors 79956 54247 8429 11313 443 459 1179 600
Post RS Errors 297 274 293 314 307 296 973 304
Upstream   US-1 US-2 US-3 US-4
Channel Type 2.0 2.0 N/A N/A
Channel ID 64 62 N/A N/A
Frequency (Hz) 25800000 39400000 N/A N/A
Ranging Status Success Success Other Other
Modulation 16QAM 16QAM N/A N/A
Symbol Rate (Sym/sec) 5120000 5120000 N/A N/A
Mini-Slot Size 4 4 N/A N/A
Power Level (dBmV) 51.50 53.00 N/A N/A
T1 Timeouts 0 0 0 0
T2 Timeouts 0 0 0 0
T3 Timeouts 0 1 0 0
T4 Timeouts 0 0 0 0
Haven't got a clue as to what any of this means but i've looked up the T3 errors and they have caused people to have the same issues as i'm having. Can someone have a look and see if any of these is abnormal??
Ta.
[MOD EDIT: For your security personal and private information has been removed from this post. Please review the Forum Guidelines]
  • 9.36K
  • 801
  • 1.96K
Re: Wireless keeps dropping - Multiple T3 errors
Your upstream is running a tad warm to say the least, and is probably the cause of the T3 errors, especially if the upstream power is fluctuating.
However, this does not mean this is the sole cause of the dropouts, you could be experiencing wireless interference as well. If this is the case, then changing the wireless channel can help. Downloading a wireless scanner like InSSIDer would help.
However, I would wait until any upstream impairments are resolved before diagnosing any wireless problems in detail.
You will need to contact VM to take a close look at your connection by, either by waiting here a few days until a VM Forum Team Member picks up the thread, or give them a call on 151 from a VM line or 0345 454 1111 for a quicker response.
  • 3.88K
  • 121
  • 203
Forum Team (Retired) Adam_L
Hi hamzer,
Thanks for the post! I am sorry to hear about your issues with your broadband having T3 errors. I apologise for any inconvenience caused.
I have tested things from here and both of your upstream power levels are too high, an engineer will need to attend and investigate this further for you.
I will send you a PM (purple envelope at the top) detailing what's required to proceed with making the booking. Please respond to me there and I'll get this sorted for you.
Take care,
Adam.
