Paulslatersky
Wired connection drops out
My wired connection keeps dropping out for a few seconds, if I unplug the network cable & plug it back in it works again, network connection isn't lost just internet.
Strange thing is that wifi is working fine at the same time, I have been watching SkyGo on my iPad with no dropout but laptop (wired connection) drops out
  • 16
ash1122
Re: Wired connection drops out
Reset network adaptor in settings to default and make sure Ethernet lead is cat 5e or above , you migh be using old cat 5 cable
1kippaxcoolcat
Thanks I will reset network adapter settings to default. I am using cat6e cable so don't think it is the cable
  • 9.36K
  • 801
  • 1.96K
If it is just the one machine dropping out I would try a new ethernet cable, as they can go bad. The locking levers snapping off is a common cause of ethernet connections becoming a bit dodgy
