Bewesy
Message 1 of 7
Will a wireless lan connect to a virgin super hub
Bought samsung wireless lan will it connect to virgin super hub
Helpful Answers
Bewesy
Message 5 of 7
Re: Will a wireless lan connect to a virgin super hub
Manual says use WIS09ABGN2 WIS09ABGN2  or WIS10ABGN however when I tried find one could samsung community pages said that  the above had been updated and that the updated lan would work
All Replies
  • 16.07K
  • 1.33K
  • 3.25K
Message 2 of 7
hiya @Bewesy welcome to the virginmedia community forum, should be able to connect whatever the device is.. since would need more details eg a model number would greatly help
Bewesy
Message 3 of 7
I have bought a Samsung wireless lan WIS12ABGN/XE . I have followed connection instructions to the letter and got as far message to say connection made but link not working. Network test but the Proxy Pin is not working
  • 20.52K
  • 541
  • 3.16K
Sephiroth
Message 4 of 7
Are you certain that the adapter spec lists your Samsung TV as being compatible?
Bewesy
Message 5 of 7
  • 20.52K
  • 541
  • 3.16K
Sephiroth
Message 6 of 7
You've marked yourself as having provided a helpul answer.
Does it work now?
Bewesy
Message 7 of 7
Still not. Working  did you message re recommended lan
