csheeran
Just joined
Wifi
What do I do about wifi when waiting for my pack to arrive? Am I wifi-less or is there an alternative Virgin Media option?
  • 22.25K
  • 851
  • 3.23K
Re: Wifi
the VM internet if for the connection, not wifi. While the superhub is wifi enabled that is not the primary way to connect. you may not get the speeds expected by wifi.
You'll need to wait for the services to be installed and activated before you can use them
csheeran
Just joined
Re: Wifi
Okay, thank you!
