Vic348
Wifi
Can I block some one from using my wifi if they already have the password
  • 329
  • 23
  • 84
KeithW
Fibre optic
Re: Wifi
The easiest and most convenient way would be to change the WiFi password
All the voices in my head are my own voices - Find your own!
If I have helped you then please click on the "thumbs up" icon.
If you feel I have helped to solve your problem then please mark my message as a "Helpful Answer"
  • 16.52K
  • 1.38K
  • 3.38K
Re: Wifi
guide to change wifi password/passhrase -> https://help.virginmedia.com/system/templates/selfservice/vm/help/customer/locale/en-GB/portal/20030... since on the hub doesn't have the option to disconnect a device.
