Chunk1981
Just joined
Wifi problem
Hi my wifi has stopped picking up my phone tablet and laptop but works with my desktop as its wired.... ive reset it pulled power reset my password several times keeps sayin wrong password can anyone help
  • 59
  • 9
eileenallison
Dialled in
Re: Wifi problem
been having bother with mine, using my wired desktop to get on to router to change password is a nightmare, i know the last time i did it, i had to get all my other devices to forget the network ie what i called my ssid, then get my devices to search again, and then when found, put in new password, hope that helps you,
  • 10.01K
  • 294
  • 625
Re: Wifi problem
Hello Chunk1981,
Thanks for posting and a big welcome to the community Smiley Very Happy
Sorry to hear about your wireless problems, it can be a pain when this happens.
Checking your connection I can see that you're using a Modem and separate Router. Could I please ask what router you've got set-up?
Hope to hear back from you soon,
Take care.
Heather_J
