England4English
Just joined
Wifi not working for some devices.
I noticed that no devices were connected via wifi. No phones or printer.
I restarted the router. No change.
I factory reset the router, some devices have connected.
One device won't connect, but I can connect it to other wifi networks. Which indicates strongly that the problem is with the router.
I've tried different channels, and checked every setting.
I have a Super Hub.
  • 1.3K
  • 65
  • 236
Knows their stuff
Re: Wifi not working for some devices.
You could try setting up a Guest wifi network and see if the device connects to it ?
It may be a security setting on the device that is causing the problem with the main Wifi connection, e.g. WPA, WEP etc.
