RayBow1988
Wifi keeps disconnecting.
We have lived in this house a couple of years now. One of the cables that have been in the house was cut, so we knew it wasn't connected to our tv. My partner assumed that the other one wasn't and cut it (grrrrr). He was able to reconnect the wires and our tv has been working perfect since he did it but our internet hasn't. It will connect for an hour and then disconnect so we have to reboot. Same happens again. No fault when I do the service checker, even when disconnected (so it doesn't even say it's switched off or anything). Is this due to the wire or just a weird coincidence? Need to know if I need to get an engineer out!
RayBow1988
Re: Wifi keeps disconnecting.
I think I may have posted in the wrong group! Sorry! Advice still appreciated x
  • 8.8K
  • 1.2K
  • 3.57K
Moved to a better place for you.
_________________________________________________________
Graham
I am a VM customer. There are no guarantees that my advice will work. To say thanks click the kudos thumb. If I have solved your problem please click the helpful answer button.
  • 9.96K
  • 290
  • 622
Hello RayBow1988,
Thanks for posting and a big welcome to the community Smiley Very Happy
Sorry to hear about your recent connection issues. I think to be on the safe side we should get an engineer around just to give everything a good once over.
I'll give you more info via PM (purple envelope, top right).
Speak with you soon,
Take care.
Heather_J
