rastle89
Wifi keeps disconnecting
For the past month or so the wifi keeps disconnecting from the laptop, we're using windows 10 and have tried uninstalling the driver on network adapters but this hasn't resolved anything. I've tried all the normal re booting of the routers multiple times, the only way to get the internet back on for a while is to restart the laptop. All other devices in the house connect to the wifi perfectly its only the laptop that causing problems. I'm aware this is probably a laptop problem but any help would be greatly appreciated. Many thanks, Rob
  • 9.96K
  • 290
  • 623
Re: Wifi keeps disconnecting
Hey there rastle89,
Welcome to the community!
Sorry to hear that your laptop is struggling to connect, it does lean towards being a problem on your laptop if all other devices are working okay. Are you able to get a hard-wired connection? You might need to fiddle around with the wireless drivers a bit more, try a roll back and an update. As a last resort you could try a USB wireless adapter and see if it'll connect via that.
Let us know how you get on,
Take care.
Heather_J
