  • 10
Nemesislee
Message 1 of 7
Wifi issues
Every so often usually up to three times a day now my wifi disconnects and disappears.
When I notice on my devices that it's not connected to wifi I go to the individual settings to re connect. Only problem is that my two wifi spots are no longer visible. This then means I have to go to the super hub and unplug it and wait then plug it back in. This corrects the problem but I shouldn't need to keep doing this? The devices also can't connect to it via the ip log in either.
Any help would be great
Helpful Answers
boronet
Message 4 of 7
Re: Wifi issues
Hello Heather,
Would the solution you suggest cure the problems listed? The issue isn't that the Wi-Fi is transmitting and not carrying to remote units. Certainly in my case there is no signal leaving the router, ie: the 2.4GHz and 5GHz lights are both on steady or off altogether. As I understand it both of these lights should blink when working correctly. Only a disconnect from power temporarily cures the problem.
All Replies
boronet
Message 2 of 7
Re: Wifi issues
I don't have a solution - just the same problem! I have a Superhub 2 and have had to reset it in excess of 50 times to restart Wi-Fi over the last 10 days. Previously it had only ever required 2 or 3 resets in 2 years. It may be coincidence but the problem started just after a break in Broadband service which lasted several hours. My PC which is hard wired to the hub is not affected.
  • 10.62K
  • 311
  • 654
Message 3 of 7
Re: Wifi issues
Hey Nemesislee,
Sorry for the wireless problems you're experiencing. Try a few different wireless channels as very often this will improve the performance of your network.
Let us know if this helps,
Take care.
Heather_J
boronet
Message 4 of 7
Re: Wifi issues
Hello Heather,
  • 10
Nemesislee
Message 5 of 7
Re: Wifi issues
I'm still getting the same issue nothing cures it. Im constantly turning it off and on to get the wifi to show up again. Terrible!!
  • 10
Nemesislee
Message 6 of 7
Re: Wifi issues
I'm currently trying it out. If it happens even once more I will post cause I've had enough. I pay for data on my phone for out and about not to use in my own home.
Lee
  • 10
Nemesislee
Message 7 of 7
Re: Wifi issues
Well trying a different band didn't work currently at home using my data up again because the wifi has stopped again !!!
