  • 7
herfranc
Wifi issue
Hi.From some time I have a constant problem with my broadband.Wifi disconnecting itself all the time...Speed goes to as low as 8 kbps!I am on fibre optic and i should get 150 Mbps.I used one of your advices and switched my superhub2 into modem mode and connected a tp link router but that didn't helped....Still losing connection few times a day...
  • 9.35K
  • 797
  • 1.96K
Re: Wifi issue
Are you ezperiencing the dropouts and slow  speeds on a connection wired directly to the hub.
You will need to test the connection wired to check if the connection from the hub to VM's is dropping.
