vc1980
Wifi drop resolved by reset
Hi all,
It's been happening for about 1-2 months where the desktop connected by ethernet has no problems but multiple wifi devices get random drop outs from the router. Somtimes it works if I turn the device to airplane mode and back but sometimes that doesn't work and I need to do a reset.
I've seen that some people have gotten great help from this forum so I was wondering if anyone can help me out.
Much appreciated!
Network log:
16/03/2017
11:56:34 GMT
66050310
Auth Success - Web login successful.
16/03/2017
09:36:44 GMT
68010302
DHCP WAN IP - removed
16/03/2017
09:35:41 GMT
68000407
TOD established
Time Not Established
84000510
Downstream Locked Successfully
15/03/2017
23:39:35 GMT
82000200
No Ranging Response received - T3 time-out
15/03/2017
22:03:50 GMT
82000200
12/03/2017
13:33:54 GMT
68010302
12/03/2017
13:32:50 GMT
68000407
TOD established
84000510
08/03/2017
22:52:36 GMT
68010302
08/03/2017
22:51:34 GMT
68000407
TOD established
84000510
08/03/2017
20:40:28 GMT
68010400
DHCP REBIND WARNING - Field invalid in response
08/03/2017
20:39:50 GMT
68010100
DHCP RENEW sent - No response for IPv4
08/03/2017
20:39:15 GMT
68010100
08/03/2017
20:38:07 GMT
68010100
08/03/2017
20:35:49 GMT
68010100
08/03/2017
20:31:12 GMT
68010100
08/03/2017
20:21:58 GMT
68010100
08/03/2017
20:03:31 GMT
68010100
Downstream
DS-1
DS-2
DS-3
DS-4
DS-5
DS-6
DS-7
DS-8
Frequency (Hz)
266750000
274750000
282750000
290750000
298750000
306750000
314750000
322750000
Lock Status(QAM Lock/FEC Sync/MPEG Lock)
Locked
Locked
Locked
Locked
Locked
Locked
Locked
Locked
Channel ID
13
14
15
16
17
18
19
20
Modulation
256QAM
256QAM
256QAM
256QAM
256QAM
256QAM
256QAM
256QAM
Symbol Rate (Msym/sec)
6.952000
6.952000
6.952000
6.952000
6.952000
6.952000
6.952000
6.952000
Interleave Depth
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
Power Level (dBmV)
6.23
6.36
6.60
6.43
6.73
7.32
7.21
7.11
RxMER (dB)
36.61
36.84
36.39
36.39
36.84
36.84
37.09
36.84
Pre RS Errors
2030
1635
747
743
295
319
378
284
Post RS Errors
297
288
309
312
278
302
375
281
Upstream
US-1
US-2
US-3
US-4
Channel Type
2.0
N/A
N/A
2.0
Channel ID
71
N/A
N/A
69
Frequency (Hz)
32600000
N/A
N/A
46200000
Ranging Status
Success
Other
Other
Success
Modulation
16QAM
N/A
N/A
16QAM
Symbol Rate (Sym/sec)
5120000
N/A
N/A
5120000
Mini-Slot Size
4
N/A
N/A
4
Power Level (dBmV)
46.25
N/A
N/A
48.00
T1 Timeouts
0
0
0
0
T2 Timeouts
0
0
0
0
T3 Timeouts
0
0
0
0
T4 Timeouts
0
0
0
0
[MOD EDIT: Personal and private information has been removed from this post. Please do not post personal or private information in your public posts. Please review the Forum Guidelines]
  • 9.58K
  • 826
  • 2.01K
Re: Wifi drop resolved by reset
The stats are fine which is unsuprising as your ethernet connection is fine.
Wireless reception is affected by many factors like Range, Client hardware, the Topograpy of your home, and the big killer, Wireless interference.
First of all, I would ensure the Hub is placed in a central, open position, away from obstacles and electrical devices.
You could try changing the wireless channel manually. Downloading a wireless scanner like InSSIDer for Windows or WiFiAnalyser for Android would help by showing you the surrounding wireless networks, the channels they are broadcasting on, and their signal strengths, so you can select the best wireless channel.
Bear in mind that the wifi scanner will not show interference from other sources of wireless interference such as A\V streaming devices, Baby monitors, Chordless phones, Microwave ovens, Plasma TVs, Security systems, etc.
Setting the Hub's radio setting to 300Mbps (or 40Mhz channel) is not advised on the 2.4GHz band as it takes up over half of the available spectrum, making it prone to wireless interference..
Using the wider, usually less congested 5Ghz band could help, if your client devices support it.
vc1980
Thank you both so much for the expertise. I will try the suggestions.
  • 8.94K
  • 386
  • 629
Hi vc1980,
Welcome to the Community!
Sorry to hear you've had some trouble with your WiFi.
How did you get on with griffin's suggestions? Let us know if you're still having any trouble.
Speak soon Smiley Very Happy
Josh
vc1980
Hi Josh, thanks for the follow up!
What I've done is move the router so it's as central in the house as I can get it. Then I logged into the router and changed it so on the 2gh it's on 144mb to and 5ghz to 214mb.
I think it may be slightly better but it seems to be happening when I'm either on my phone or tablet.
Again, no problems with my desktop which is on ethernet.
I thought I'd observe it more before I reported back so perhaps there is a pattern.
Thought I'd give you an update in the interim though.
Is there anything else I should be looking at in the mean time?
  • 3.55K
  • 208
  • 995
Sololobo
Wise owl
Modem mode, and a decent 3rd. party wireless router?
It's What I Do.
I Drink and I
Remember Things.
