  • 5
Garyhobbs1
Wifi drop out
Lost 2g signal, 5g was working. Changed 2g channel worked ok. Lost both this morning. Reboot all work.
Hope someone can help with this issue.
Date
Time
Error Number
Error Description
82000400
Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out
03/02/2017
08:44:50 GMT
82000400
03/02/2017
08:44:14 GMT
84020200
Lost MDD Timeout
03/02/2017
08:44:14 GMT
84020200
Lost MDD Timeout
03/02/2017
08:44:14 GMT
84020200
Lost MDD Timeout
03/02/2017
08:44:14 GMT
84020200
Lost MDD Timeout
03/02/2017
08:44:14 GMT
84020200
Lost MDD Timeout
03/02/2017
08:44:14 GMT
84020200
Lost MDD Timeout
03/02/2017
08:44:14 GMT
84020200
Lost MDD Timeout
03/02/2017
08:44:14 GMT
84020200
Lost MDD Timeout
03/02/2017
08:44:08 GMT
84000500
SYNC Timing Synchronization failure - Loss of Sync
03/02/2017
08:44:08 GMT
84000500
03/02/2017
08:21:18 GMT
68010302
03/02/2017
08:20:40 GMT
68000407
TOD established
03/02/2017
08:20:26 GMT
84000510
Downstream Locked Successfully
03/02/2017
08:11:46 GMT
68000409
TOD not Established
03/02/2017
08:11:25 GMT
82000400
03/02/2017
08:11:25 GMT
82000400
03/02/2017
08:10:25 GMT
84000500
Helpful Answers
  • 3.01K
  • 383
  • 952
Re: Wifi drop out
Log doesn't look very healthy.  Can you post the figures from the hub's downstream and upstream screens to see if there is anything amiss with the power levels.
______________________
Scott
  • 3.01K
  • 383
  • 952
Re: Wifi drop out
Downstream levels look OK. The upstream levels are within the recommended range but not by much, the max recommended is 51 dBmv and they are showing as 49.5 currently. If they were to fluctuate a bit higher then that could explain the errors in the log.
This will probably need a technician visit to bring down the upstream levels. You can call VM and see if they agree with me (or can provide another explanation for the errors) and try to book a visit or wait for the VM staff to get to this thread and they can help you book a visit.
Scott
All Replies
  • 3.01K
  • 383
  • 952
Re: Wifi drop out
Scott
  • 5
Garyhobbs1
Re: Wifi drop out
Thanks for your reply.
Downstream Channels
Lock Status Channel ID Frequency Modulation Rx Power RxMER Pre RS Errors Post RS Errors
Locked 2 242750000 Hz 256 QAM 2.9 dBmV 37.9 dB 727 308
Locked 1 234750000 Hz 256 QAM 3.0 dBmV 37.6 dB 1988 282
Locked 3 250750000 Hz 256 QAM 2.6 dBmV 37.4 dB 1479 974
Locked 4 258750000 Hz 256 QAM 2.7 dBmV 37.6 dB 406 307
Locked 5 266750000 Hz 256 QAM 2.5 dBmV 38.3 dB 278 269
Locked 6 274750000 Hz 256 QAM 2.7 dBmV 38.3 dB 304 302
Locked 7 282750000 Hz 256 QAM 2.9 dBmV 39.0 dB 967 964
Locked 8 290750000 Hz 256 QAM 2.8 dBmV 38.3 dB 1051 1047
Upstream Channels
Lock Status Channel ID Frequency Modulation Tx Power Mode Channel Bandwidth Symbol Rate
Locked 18 39400000 Hz ATDMA 49.5 dBmV 64QAM 6400000 Hz 5120 Ksym/sec
NotLocked 0 0 Hz 0 dBmV 0 Ksym/sec
Locked 19 32600000 Hz ATDMA 49.5 dBmV
  • 3.01K
  • 383
  • 952
Re: Wifi drop out
Scott
  • 5
Garyhobbs1
Re: Wifi drop out
Thankyou i appreciate your advice.
  • 6.62K
  • 174
  • 438
Re: Wifi drop out
Hi there Garyhobbs1,
Really sorry to hear about the connection fault experienced.
I've had a look into this for you and can see the level issues as mentioned by SCA1972.
The timeouts are also a little high considering the equipment was not long refreshed.
I'd like to arrange an engineer appointment for you and I've sent you a private message so that we can get this booked in.
Speak to you soon,
Nat_J
