  • 14
gill139
Wifi drop out on laptop
I have been reliably informed that I should be able to run 10 devices on wifi. Can you offer advice as to why, when in the same room, the Windows 7 laptop loses wifi connection when the Asus tablet is happily working fine?
  • 10.82K
  • 308
  • 631
Re: Wifi drop out on laptop
Hiya gill139,
Thanks for taking the time to post on the community.
Sorry to read that you are having issues with the wireless connection.
Does this only happen on the laptop?
If so, have you tried to update the drivers?
If this happens on other devices you can try to change the wireless channel to improve the connection.
I wanted to check your connection for any issues, however the Super Hub is showing as offline and not polling any data. Is the router turned off as not in use?
Hope to hear from you soon
Sam
