  • 6
JakeBousfield
Message 1 of 8
Wifi disconnecting or a second or two
Hi Guys,
I'm facing a very annoying problem with my broadband... When gaming or using Sky Go my internet disconnects for literally a second then reconnects. This doesn't seem to be a problem when browsing the internet however online gaming you are thrown out of the game due to connection issues...
This happens both wireless and through an Ethernet cable... apart from the disconnecting the internet speed etc is fine.
I spent over an hour last night on the phone to VM, I was advised my router settings were incorrect and a reset would solve the problem. After re-setting my router the problem still persisted (I was still on the phone) so I advised the VM employee who at this point was stumped so I was transferred to a 'Gadget help team?' explained my problem to a guy and then was cut off Smiley Sad
I'm hoping this is an easy fix as the last thing I want to do is spend another hour on the phone.
can you help please?
  • 6
JakeBousfield
Message 2 of 8
Re: Wifi disconnecting or a second or two
Anyone????
  • 9.35K
  • 799
  • 1.96K
Message 3 of 8
Posting some basic diagnostic info may help.
Navigate to the hub's GUI using http://192.168.100.1
Don't log in, click the Router Status button in the top right of the screen.
Copy \ Paste the Downstream, Upstream, and Network Logs.
Don't worry about the formatting, just obscure your IP and MAC addresses in the logs
  • 6
JakeBousfield
Message 4 of 8
Downstream
DS-1 DS-2 DS-3 DS-4 DS-5 DS-6 DS-7 DS-8
Frequency (Hz) 243000000 235000000 251000000 259000000 267000000 275000000 283000000 291000000
Lock Status(QAM Lock/FEC Sync/MPEG Lock) Locked Locked Locked Locked Locked Locked Locked Locked
Channel ID 2 1 3 4 5 6 7 8
Modulation 256QAM 256QAM 256QAM 256QAM 256QAM 256QAM 256QAM 256QAM
Symbol Rate (Msym/sec) 6.952000 6.952000 6.952000 6.952000 6.952000 6.952000 6.952000 6.952000
Interleave Depth I=12
J=17 I=12
J=17 I=12
J=17 I=12
J=17 I=12
J=17 I=12
J=17 I=12
J=17 I=12
J=17
Power Level (dBmV) 4.58 5.46 4.91 5.76 6.79 7.77 8.04 7.32
RxMER (dB) 36.39 36.39 36.17 36.39 37.09 37.09 37.36 37.09
Pre RS Errors 6675 22682 6502 2276 800 716 570 1222
Post RS Errors 299 299 302 301
  • 6
JakeBousfield
Message 5 of 8
Upstream
US-1 US-2 US-3 US-4
Channel Type 2.0 2.0 N/A N/A
Channel ID 4 1 N/A N/A
Frequency (Hz) 25800000 46200000 N/A N/A
Ranging Status Success Success N/A N/A
Modulation 16QAM 16QAM N/A N/A
Symbol Rate (Sym/sec) 5120000 5120000 N/A N/A
Mini-Slot Size 4 4 N/A N/A
Power Level (dBmV) 36.46 38.25 N/A N/A
T1 Timeouts 1 1 1 1
T2 Timeouts 0 0 0 0
T3 Timeouts 1 0 0 0
T4 Timeouts 0 0 0 0
  • 6
JakeBousfield
Message 6 of 8
Super Hub
Sign In
home
Router Status
First Time Last Time Priority Error Number Description
20/01/2017 13:16:42 GMT 20/01/2017 13:16:42 GMT Critical (3) 82000200 No Ranging Response received - T3 time-out
20/01/2017 13:16:34 GMT 20/01/2017 13:16:34 GMT Error (4) 68010302 DHCP WAN IP - #######
20/01/2017 13:16:00 GMT 20/01/2017 13:16:00 GMT Error (4) 68000407 TOD established
20/01/2017 13:15:51 GMT 20/01/2017 13:15:51 GMT Notice (6) 84000510 Downstream Locked Successfully
20/01/2017 13:15:40 GMT 20/01/2017 13:15:40 GMT Error (4) 68000407 TOD established
20/01/2017 13:15:22 GMT 20/01/2017 13:15:22 GMT Notice (6) 84000510 Downstream Locked Successfully
20/01/2017 13:15:21 GMT 20/01/2017 13:15:21 GMT Warning (5) 84020300 MDD message timeout
20/01/2017 13:15:21 GMT 20/01/2017 13:15:21 GMT Warning (5) 84020200 Lost MDD Timeout
20/01/2017 13:14:50 GMT 20/01/2017 13:14:50 GMT Error (4) 68000409 TOD not Established
20/01/2017 13:14:39 GMT 20/01/2017 13:14:39 GMT Critical (3) 82000400 Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out
20/01/2017 13:14:35 GMT 20/01/2017 13:14:35 GMT Critical (3) 82000400 Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out
20/01/2017 13:13:50 GMT 20/01/2017 13:13:50 GMT Warning (5) 84020200 Lost MDD Timeout
20/01/2017 13:13:46 GMT 20/01/2017 13:13:46 GMT Critical (3) 84000500 SYNC Timing Synchronization failure - Loss of Sync
© 2010 Virgin Media. All rights reserved.
[MOD EDIT: Personal and private information has been removed from this post. Please do not post personal or private information in your public posts. Please review the Forum Guidelines]
  • 6
JakeBousfield
Message 7 of 8
Bump
  • 6.62K
  • 174
  • 438
Message 8 of 8
Thanks for the information provided JakeBousfield and apologies for the connection fault experienced,
I've had a look into this and I'm unable to detect any faults either via the equipment levels or network segment at the moment.
Could you try retesting the connection if possible?
Speak soon,
Nat_J
