davida10
Wifi boosters
Last week my broadband was working, but my wifi was not (tablets, etc. connecting to the signal but no internet connection.
Virgin managed to reset the wifi however:
1)  it is painfully slow.
2) my wifi booster - a TPLink 300 now does not boost the signal, in fact quite the opposite. It blocks the signal.
Today has been a real challenge to connect with anyone at Virgin for advice, so does anyone know:
a) how to increase wireless speed.
b) whether my TP Link will work with Virgin wifi (I have done the resets with WPS.)
  • 1.27K
  • 94
  • 235
stevedh2
Knows their stuff
Re: Wifi boosters
As far as I can tell a tplink N300 is effectively a wifi repeater, and they can make your wifi worse as some just rebroadcast on the same channel.
Assuming you can't create another wifi access point using an Ethernet cable and an old router or something
go for one of the powerline wifi range extenders as they will do a much better job.
  • 979
  • 80
  • 252
vircom
Well-informed
Re: Wifi boosters
Powerline extender / access point works well for me.
  • 7.57K
  • 188
  • 441
Re: Wifi boosters
Hi davida10,
Welcome to the forums, I am sorry to see you have been having trouble with your connection.
I have taken a look and things seem to be ok from this side.
It may help to take a look at Getting the best WiFi Signal, specifically - 'WiFi Win #5 - Get rid of blackspots'.
Let us know how you get on Smiley Happy
All the best
Emma
