Evyag3
Wifi and wired not working
The wifi on the superhub2 essentially stops whenever all of the Ethernet ports are being used. Why is this?
  • 10.82K
  • 308
  • 631
Re: Wifi and wired not working
Hi Evyag3,
Sorry to read that the wireless connection doesn't work when the Ethernet ports are in use. This is unusual.
Do the devices still show as connected to the network when this happens?
Does this happen on both 2.4 GHz and 5 GHz?
Have you tried a factory reset (be mindful that any saved settings will revert to default settings) to see if that helps?
Does it only happen when all 4 ports are in use? Just wondering as if you had 3 in use, then connected a fourth does it then stop working as it might be the cable?
Let us know how you get on
Sam
