  • 5
james_87
Message 1 of 180
Wifi Light Flashing on my hub3
Hi there
My WiFi light keeps flashing on my virgin hub 3
james.v.tooey
Tags (1)
Helpful Answers
  • 367
  • 10
  • 16
Logic800
Fibre optic
Message 2 of 180
Re: Wifi Light Flashing on my hub3
Try giving it a reboot. Switch off and then on again a few moments later using the switch at the back by the power input socket.
  • 20.73K
  • 554
  • 3.21K
Sephiroth
Message 9 of 180
I've raised this behind the scenes to find out what it means. There is no publicly available Hub 3 documentation and such documentation as the Superusers have doesn't cover a flashing wireless light.
Cheers
  • 20.73K
  • 554
  • 3.21K
Sephiroth
Message 10 of 180
Well, according to the Polish manual for the identical gateway, flashing green means it is searching for a connection. (Thanks to Muddie for finding that).
Still a mystery as to exactly what that means, though. The Hub 3 is essentially a base station that beacons for others to find. So we will get that looked into.
Cheers
All Replies
  • 367
  • 10
  • 16
Logic800
Fibre optic
Message 2 of 180
  • 20.73K
  • 554
  • 3.21K
Sephiroth
Message 3 of 180
What colour is/was the flashing light?
Did WiFi work during the episode?
  • 5
james_87
Message 4 of 180
green but being doing it all day
james.v.tooey
  • 20.73K
  • 554
  • 3.21K
Sephiroth
Message 5 of 180
Does WiFi work while this is happening?
And did you reboot the Hub 3?
  • 5
james_87
Message 6 of 180
its does some times and some times it dont
james.v.tooey
  • 20.73K
  • 554
  • 3.21K
Sephiroth
Message 7 of 180
Did you reboot the Hub 3 as suggested?
You gotta give us more information. When it doesn't work, what happens? How do you reconnect?
  • 5
james_87
Message 8 of 180
yes did reboot as suggested but still get light like 20mins later the light back on flashing
wen wifi not working my phone and tablet show as connected but no web pages loading or whats app will not work
james.v.tooey
  • 20.73K
  • 554
  • 3.21K
Sephiroth
Message 9 of 180
Cheers
  • 20.73K
  • 554
  • 3.21K
Sephiroth
Message 10 of 180
Cheers
